non ls1 help front wheel drive clunking
Yeah, sounds like you need to replace w/e it is in the front axle that is worn out. A buddy of mine used to hammer on his POS honda and he'd constantly break his front axle (I guess they call it a CV joint?) and also screw up w/e it is in that boot that connects everything together and it would make the clunk sound you're hearing (especially when turning). It's no big deal to replace either, those honda morons would snap the joints like candy in all of their front wheel drive blunders.
So..yeah.. if that answers it.. I know what it is but have no idea what it's called. Sorry!
damn it now thats two things I have to fix on it. Loss all my cooling fluid either through a broken hose or head gasket and suspect the hose over the gasket as it runs fine unitl it gets hot.... car only gets driven about 3 miles at a time. Just the runabout car. How long can I go before its real issue on the cv joint? Whats the worse that could happen with it? I know nothing about FWD's. IT clunks when turning but not going straight.
teh PuRpL3z
Here.... read up on how they work. Then you can decide whether you want to let it go or not.
http://en.wikipedia.org/wiki/Constant_velocity_joint
