Door skin coming undone. 4 Attachment(s) The outer door skin on my '00 TA seems to have come loose at the top on front and rear. It's causing the top of the door skin is sit out a little, causing ridiculous wind noise. Attachment 670972 Attachment 670973 Attachment 670974 I believe it's also preventing the window from following the track as I have to pull the window up or it seems misaligned as it goes up and won't go all the way. Attachment 670975 What I'm wondering is if it would be worth it to try and have it fixed, or if I should just get a whole new door. Also, what would my options be as far as repair? Thanks in advance :) |
Bring it to a body shop, they can re glue back on. |
if you take the door off so you can get some clamps on it, you can use the super glue gel. load up area that is coming apart. i put towels where the clamps go to prevent damage to the paint. when you apply the clamps wipe down the areas where the glue seeps out and let it sit for about an hour. done this to both of my doors and never had a problem since. |
Originally Posted by slow93z
(Post 14311465)
And thats what GM gets for using Fiberglass for freakin doors. Hope that's an easy fix for ya OP. |
Thanks. I'll probably get around to it this weekend and let you guys know how it goes. |
funny... i got this same problem. I've been holding out because the previous owner tried to reglue it, unsuccessfully. So i've been waiting to find a good adhesive. |
i used the brand "Super Glue" but you can get it in the gel form instead of the thin watery stuff. il see what we use at the body shop if you would feel more comfortable doing that. |
Originally Posted by BirdsSince16
(Post 14300973)
The outer door skin on my '00 TA seems to have come loose at the top on front and rear. It's causing the top of the door skin is sit out a little, causing ridiculous wind noise. http://i283.photobucket.com/albums/k...2-31143630.jpg http://i283.photobucket.com/albums/k...2-31143708.jpg http://i283.photobucket.com/albums/k...2-31143653.jpg I believe it's also preventing the window from following the track as I have to pull the window up or it seems misaligned as it goes up and won't go all the way. http://i283.photobucket.com/albums/k...2-31143804.jpg What I'm wondering is if it would be worth it to try and have it fixed, or if I should just get a whole new door. Also, what would my options be as far as repair? Thanks in advance :) |
(Post 14319113)
what im seeing in the pictures my door use to do. there is a pivoting roller at the bottom of the glass that breaks off sometimes. i just went through this with my window. can you slide the window back and forth? |
yes from the front to the rear |
In the 2nd picture, you have the SAME exact rubbing/missing paint that I do on mine in the upper left of the edge of the door. It could be a clone of my rubbing spot. Can't figure it out either as opening and closing it, it isn't anywhere near to hitting the edge of the fender. So, just weird. |
I had this exact issue with my previous camaro, however it was only at the rear of the door, not by the mirror. My window was slightly loose and was a noisey mess over 60mph. The proper adhesive to use is by 3M for gluing SMG panels, HOWEVER I cheaped out and got a tube of PL Premium(4 bucks from Home Depot) and it worked like magic. In my case however there was no issue with the window getting caught on the track(just loose when full up on the hwy), so in your case I would try the following: Have someone put pressure on both the front and rear of the door where it is seperating, then try putting the window up/down. Do this BEFORE applying glue! If it doesn't bind, i would try gluing it with the PL. Your most difficult part will be getting clamps into the front part of the door. I would just grab a beer and a buddy and put pressure on both ends for 20 mins while the door is closed HTH |
Originally Posted by NDFORSPD
(Post 14332535)
I had this exact issue with my previous camaro, however it was only at the rear of the door, not by the mirror. My window was slightly loose and was a noisey mess over 60mph. The proper adhesive to use is by 3M for gluing SMG panels, HOWEVER I cheaped out and got a tube of PL Premium(4 bucks from Home Depot) and it worked like magic. In my case however there was no issue with the window getting caught on the track(just loose when full up on the hwy), so in your case I would try the following: Have someone put pressure on both the front and rear of the door where it is seperating, then try putting the window up/down. Do this BEFORE applying glue! If it doesn't bind, i would try gluing it with the PL. Your most difficult part will be getting clamps into the front part of the door. I would just grab a beer and a buddy and put pressure on both ends for 20 mins while the door is closed HTH I wasn't able to get around to it this weekend to really do anything, but I grabbed the towels and a clamp and just clamped the back and it seemed to help, but it was a small clamp. Recently found the fix for interior door panel cracks, so I'll probably get on that first, as I have it on both sides. As for the rubbed paint on the front of the door, I had the same problem with my 98 Firebird. Couldn't figure that one out either. Thanks again for the help, guys. |
go to a body shop supply store there is a SMC adhesive you can buy its around $25. |
incorrect, gm and every other company uses panle bond, that skin is panle bonded to that frame it does look like the door should come off to correctly fix the skin and re adjust the window, any body shop can fix this for you if you buy panle bond i recomend fusor but then your buying the product and the gun which is expensive |
Originally Posted by bdyman
(Post 14466508)
Hahaha Ive got the same damn problem on my convertible. Stops early and shit. Sides i think my track is bad cause during the summer when i roll it down it makes a horrid ass noise. but i thought i was the only one that has these problems. |
Get a tube of PL Premium Advance from Home depot/Lowes. Cake that fucker in and use clamps to hold it there, gotta leave it overnight to cure but it hardens like a rock. Half my passenger side door skin is glued with this stuff. |
3 Attachment(s) If your willing to take the door off. kent brand sealer( glob it on ) heavy clamps on the doors ends so it gets a good hold also lay the door on the shell so the weights on the shell, after a day or good dry, fiberglass over it body filler over the fiberglass. it worked for my door and hatch... don't have pics of the door:| also make sure your door or fender doesn't need to be adjusted mine was hitting the fender cause the skin was separating after putting the door back on the fenders were still tapping and had to be adjusted ( sagging door ) |
© 2024 MH Sub I, LLC dba Internet Brands
