Removing pins for fender liner How do you remove the two pins that attach the fender liner to the fender in the rear of the wheel well? THey looked like the ones that you push the center in to release them. I tried that but they wouldn't budge, and when I tried to pry them out they tore. Also, does anyone know where I can get a replacement? |
I'm not sure if these are it, but try GM 20664092 |
Originally Posted by blue09rocket
(Post 19549227)
I've look everywhere for something that looks like what came from the factory, but cannot find it. Attached are pictures of what came off my car and what GM 11589290 looks like. The factory clip appears to have a long center rod that is pulled out then draws 3 arms from the inside. I got 11589290 to work, but it was a pain because you first have to draw the fender liner in close. So nothing special about 11589290 so you could pretty much use any similar style 1/4" push clip. Original factory front fender clip (left) and replacement part 11589290 (right) https://cimg6.ibsrv.net/gimg/ls1tech...d70580e02a.jpg Factory clip extended https://cimg9.ibsrv.net/gimg/ls1tech...abb9f408a9.jpg Factory clip compressed a little https://cimg8.ibsrv.net/gimg/ls1tech...7dcdcdb76a.jpg GM part 11589290 https://cimg0.ibsrv.net/gimg/ls1tech...a9376e314d.jpg |
are you referring to the push pull type or the phillips screw head type ? .....i have the phillips head type on my fender liner |
Neither 20664092 or 11589290 have the OEM hex head on it. Maybe they changed the design to phillips head? http://www.hawksmotorsports.com/cama...02-pack-of-10/ https://cimg5.ibsrv.net/gimg/ls1tech...d62aa45c71.jpg |
That would would work as well. On the factory clip there's no head on it. Imagine that rod much longer and sticking out of the hole and the three arms lying flat. Then you insert through the fender and fender liner holes and pull on the center rod it will draw the end of it and start extending the three arms until the fender liner is snug up against the fender. Then the center rod breaks off at the top. There's no reusing that one. So what they put on in the assembly plant and what they sell to replace it are two different pieces. Now I'm obsessed with that factory one. It's a pretty ingenious little clip! |
there are 2 ( or 3 ? ) small 7mm head screws and the plastic pins... you are not thinking the plastic pins go where the screws go are you ? I just took out my fender liner the other day...... looking at the layout.....it shows 2 plastic screw pins that go thru the liner into the fender...along the top of the fender ( num 32 ) and if you have a trans am....another one that goes thru the fender ...liner...and into the lower side skirt |
The plastic pins are much bigger in diameter than the screws. He's saying that the replacement plastic pin is different than what is used during assembly and that the ones used during assembly are not sold to the public and he is correct. The workaround to this finding someone that works at a GM plant, showing them the part schematic, and having them tell someone on the assembly floor to cross reference their internal part number with the external part number of the push pin. Then have them grab you a handful of them. Done and done. |
I was at my local hardware store a while back and found one of these freaking poly fasteners. They are called plastic rivets and you need a plastic rivet gun to install them. Like metal rivets, they draw the surfaces close together and HOLD THEM from the inside, unlike push type fasteners that just squeeze outward. Also like metal rivets though, they can only be used once. This tool and rivets are available all over the internet. Plastic rivets and rivet gun https://cimg9.ibsrv.net/gimg/ls1tech...f7815f1589.jpg |
where do plastic rivets go in the liner ? |
Originally Posted by sjsingle1
(Post 20096190)
where do plastic rivets go in the liner ? If you already have the reusable push-pins in these locations (which it sounds like you might based on your posts above) then someone must've changed them at some point. All four of my 4th gens, '98-'02, came with the rivet style from the factory. |
These are a must have when doing the wire hide mod under the fender liner. Nice find. Winning! |
all the cars I have worked on have not had rivets in them.....strange |
(Post 20098597)
© 2024 MH Sub I, LLC dba Internet Brands
