Outer door shell replacement for a 98 firebird
I'm looking for a door shell for a 98 firebird do you guys know if the 93-97 doors work with the 98? I heard the 93s-97s have 3 bolts and the 98s plus have 2 bolts do you guys know if it'll still fit properly with a 93 door?
Update for you. If you swap the door, swap your door lock mechanism as well. My car being an 02 had the retained accessory power shut off built into the door lock mechanism. The 95 that I got the door off of did not. The 95 had the same door lock mechanism shell, even had a place to insert the plug for the RAP, but there were no pins inside that slot to actually connect to so my car was not seeing that I was opening the door.
