98-02 Camaro to Corvette C5 brake conversion brackets (NO SPINDLE CUTTING REQUIRED#2
These only work with LS1 spindles & abutment brackets. You can use LS1 or C5 calipers. If you have a 98 or newer car the only other thing you need is the C5 rotors.No spindle cutting requied & you can go back to stock anytime.93 to 97 cars will need the LS1 spindles. These 1/2 inch thick caliper adapter brackets allow you to use 12.8" X 1.26' C5 corvette rotors and the PBR- made C5 front calipers on any 93-02 F-Body. They come complete with driver's and passenger's side brackets & thorough instructions and complete list of GM parts needed to complete installation. You will need LS1 or C5 calipers and C5 rotors to finish installation. LT1 cars will need the LS1 spindles & brackets.Total weight of installed components is equal to what is removed from LT1 cars, 25 lbs. They are cut from steel & powercoated black. Installation is identical to the Baer GT+ system . All OEM 17" wheels 96 and newer should fit. Some after market wheels need spacers.
PRICE IS $75.00 SHIPPED
PACKAGE INCLUDES: BOLTS, SPACERS, WASHERS, INSTRUCTIONS AND BRACKETS
i also have a hypertech programer for an 02 camaro/firebird $150.00 shipped obo
rear o2 sensors, & stock thermostat housing $40.00 shipped
i also have a hypertech programer or an 02 camaro/firebird $150.00 shipped obo
