**Lt1 Aftermarket** Comp 1.6rr, Comp lifters, Accel 300+, accel coil,Converter, Heads 5 Attachment(s) Have some aftermarket and stock lt1 stuff for sale was used on my '95 Camaro Items: -Accel 300+ digital ignition box that has a multiple-spark discharge up to 2,500 rpm for easier starting and greater burn efficiency, which also results in quicker acceleration and improved throttle response also has an adjustable rev limit that does not require seperate pills like MSD. Very easy to hook up good performance worked well for me -Matching Accel 300 COIL Box an coil $100 -Good Used ICM and bracket. ('95) -$25 - Set of 16 Comp Magnum Roller tip rockers Ratio 1.6, 3/8 used for around 5k miles, still in good working condition -$100 -Set of 16 Comp Hydraulic roller Lifters working but been sitting for a month or 2 so a little dirty- $80 -Stock Stall torque converter, fairly new only about 6 months old = 2k miles got it when i rebuilt the 4l60e upgraded shortly after. $100 - Accel Cap and rotor Vented 95-97 good working order arout 5k -$100 -Couple of old optis 1 93 and 1 95 unsure of condition $20 each - Also have some stock casting heads that have all the valves but missing 8 springs, they are comp beehive 918 (ive been using when my springs go) contact if interested ill give you more info All items can be shipped from NC and all reasonable offers will be considered PM me Thanks |
What part number are the rocker arms? Are they SA? |
No they are Non SA 1418-16 |
Can you PM me price on the rockers shipped to 80634. |
300+ SOLD still some good rockers and stuff here guys |
bump good price for some good reliable rockers guys |
bump need to push them guys |
© 2024 MH Sub I, LLC dba Internet Brands
