True LT4 - Built Short Block, Dart 215s and LS PCM Conv Kit
Category: Accessories
Price: $4000
Location (State): MI
Item Condition: Brand New
Engine: LT1/LT4
LS Engine?: Non-LS Part
The motor specs are as follows: ($2500 for just the short block)
LT4 block .020 over (spent 800 on block without machine work)
Cola race crank (stock stroke)
Eagle H beam rods (6.0 in stroke)
ARP rod bolts and main studs
Diamond custom pistons (#11130) 10 to 1 depending on heads (they are a forged 2618 aluminum piston's)
Heads are Dart 215's fully upgraded ($1500)
They have dual springs for a solid mechanical roller good to in the .700 lift
I believe they have titanium retainers, don't remember 100%
The come assembled with guide plates, one box has been opened to look at it the other is still sealed in the box
Heads cost me over $2k with all the bells and whistles
They also have boost valves in them. I believe they are a 1 piece stainless steel valve.
Additional specs:
Dart LT1/LT4 Pro 1 Aluminum Cylinder Heads Details
Intake Ports: 215cc
Specifications:
Valvetrain: Standard SBC 3/8" stud mount or can be modified to 7/16"
Intake Port Location: Stock
Intake Port Dimensions: 1.190" x 2.075"
Intake Flow: 257 cfm @ .500" lift/28"
Exhaust Port Location: Stock
Exhaust Port Dimensions: 1.410" x 1.350"
Exhaust Flow: 172 cfm @ .500" lift/28"
Manifold: LT-style
Pushrod Length: Stock (should always measure)
Pushrod Guide Plate: Not used (uses stock-type self-aligning rockers)
Retainers: Steel 7°
Stud Girdle: Any standard girdle
Valve Length: 4.890"
Valve Stem Diameter: .3415", 11/32"
Valve Guides: .439" OD Mag-Bronze (.002" press)
Valve Guide Length: 2.100"
Valve Guide Clearance: .0014" to .002" (using Dart .3415" valve stem)
Valve Guide Spacing: Moved .030" from stock
Valve Seats: Hardened Ductile Iron, .006" press
Valve Seat Dimensions: Intake 2.160" x 1.810" x .350", Exhaust 1.650" x 1.350" x .350"
Valve Seat Angles: Intake 32°, 45°, 60°, 70°; Exhaust 37°, 45°, radius
The motor was assembled with the idea of making 800-900 hp and the heads were chosen to support that.
I do also have a 230/236 blower cam. I don't remember the specs 100% but I'd throw it in for 100 bucks.
In addition to this, I have hardware to convert the LT1 over to an LS1 PCM. This kit includes the following:
Timing cover, ls1 crank/cam sensor and adapter plate and everything needed to complete the conversion (extension pigtails, connectors, ls1 knock sensor.... all the little stuff).
All the details can be found here and I still have receipts. http://www.eficonnection.com/eficonnection/24xLT1.aspx
I have an LS1 PCM also. I do have a harness made for it but want to keep it for my current project, I can make a harness for your setup as well.
I have ~1000 in just swap parts. I will sell kit minus PCM and Harness for $650.
Kit with PCM for $725.
Kit with PCM and Harness, 100% plug and play. $1300 if you provide harness.
I also have the following. Stock LT1 fuel rails $25
F-body LT1 K-member - $40.
LT1 Fuel Rails upgraded with return port - $60
I also have full LT1 accessory drive - $100
Vortech T-Trim blower brackets - $50
LT1 Rack and Pinion - $50 (no leaks works well)
I will separate it all or sell it complete. I have TONS of pictures wayyyy tooo many to put on here please email me and I will respond promptly with pictures of what you want to look at. Very motivated to sell, need the cash to finish my other project that took priority
I will sell the entire thing as a package deal for $5k.... Basically all you would need is an ls1 harness and I will trade you mine. (harness needs to be from a 99-02 f body). Injectors, lifters and pushrods, and a cam depending on what you decide. The headers get the job done. The intention was to be running below 10's with this setup in front of a TH400 and Ford 9" in a Trans Am. I would also recommend a super victor modified manifold. That was the plan just never got around to it.
Make me offers on anything/everything. I am negotiable
Pics can be seen here: http://detroit.craigslist.org/okl/pts/4033749591.html
