6.0, torquer v2, throttle body, etc I have a few left over parts that need a new home. I had originally planned to use a 6.0 but have since found a 408 so all the 6.0 stuff needs to go. 05 6.0 LQ4 was told it had 64k miles when I bought it. It is completely stock other than having heads studs, I had planned on changing the heads, and had already removed them before I bought the 408. Since I already had the head studs I just went ahead and but them in. The engine is complete with all accessories. I don't believe I have a harness for it but ill have to check. SOLD 03 LQ9 pistons no rings or rods $100 05 LQ4 rotating assembly low mileage $200 professional products polished 85mm throttle body $175 TSP Torquer V2 was told it had 50 miles when I bought it. I never installed it and it is too small for the 408. SOLD gto manifolds SOLD truck manifolds $50 1 317 $50 have the other one but it is cracked. I will ship any of it but buyer pays shipping. I also need a 4150 cathedral intake, ls3 water pump, and 42lb injectors. I will get pictures up soon. |
4 Attachment(s) couple pictures Ill get more as needed |
Pics of torquer? |
Any pics of the 05 rotating assy.? |
It is still in the block I will be removing it tomorrow. I was told it had 94 miles on it by the junk yard but I think it has a few more than that. |
LSA on torquer? |
Cam sold I'll get pictures of everything else up today. |
where in georgia are you located ? |
Villa Rica/temple exit 19 on i-20 |
6 Attachment(s) Here are a few pictures. The lq4 stuff has not been cleaned just removed from the block and pictures taken. I only had time to clean one of the lq9 pistons but the other 7 should clean up just as well. |
any idea on what shipping is to 40258 louisville ky for the 6.0 engine |
355 if you need a lift gate 235 to a business. |
Damn I those the lq9 pistons but I got 3 of those already but got a ring set for the 1.5, 1.5 pistons which I have 5 pistons of!! Umm what to do?? |
If you want the lq9 pistons as they are, you finish the cleaning and ring removal. Ill take $80 and we can split the shipping. The rings may be useable but I know there is one broken one and the others are rusty. |
Ok I had it wrong I got 4 of these which are the correct ones 1.5,1.5,3.0 rings!! |
Pm sent |
© 2024 MH Sub I, LLC dba Internet Brands
