TH400 Built, Brake, 1200HP rated, low miles... COMPLETE BOLT IN SWAP & mo for F-bodys
Category: Drivetrain
Price: $3000
Location (State): NY
Item Condition: Used
LS Engine?: Fits LS Engine
I am located in Buffalo NY but I make trips regularly too the "Howell/Brighton Area" just outside Detroit. Also I will ship at the buyers $$
TH400 Complete swap... Trans brake and more
Low mileage
This is a complete swap for your fbody v8 cars only
-Very nice smaller diameter toque converter 3,500stall
-comes with all modules, transmissions plugs for the computer, dipstick, tube, shift cables. Ect... May have ARP bolts as well
-SideWinder shifter and 4th gen console made to fit
-Custom length 3" Aluminum drive shaft
-Fbody Transmission crossmember
-Autometer Trans temp gauge (sport comp II) as well as a single pillar 4th gen gauge pod
-Bulletproof flywheel SFI 29.1
-Transmission Is a Monster "SS Extreme Performance" TH400 rated for 1,200HP+
Electronic transbrake
Reverse Manual Valve Body
Nice deep pan w/ sending unit for the temperature gauge
Upgraded yolk
And much more.
Everything listed here has just over 3,000 miles and was used for 1 season on and off at the track.
$3,000 obo for everything mentioned
Thank you. Adam B
Here's a list of some of the Internals.
P.S. last picture is todays sale cost of this transmission New.
dumBillet Input Drum & Shaft
dumBillet Forward Clutch Hub
dumSmooth Cam Drum w/34 element sprag
dumStraight cut planetarys
dumPrecision Master Overhaul Kit
dumNew Gaskets, Seals, O-rings, Teflon rings
dumNew Governor Filter
dumNew Rubber Seals for Drums & Pistons
dumNew High Performance Friction Clutches
dumNew Steel Friction Plates
dumNew Steel Check *****
dumNew Double Lip Seals (Front & Rear)
dumNew Alto Red Eagle Race Clutches
dumNew Brass Washer Kit "NO PLASTIC HERE"
dumNew Bushings & Torrington Bearings
dumSuperior High Performance Reprogramming Shift Kit
dumSuper Pump
dumNew Pump Bushing
dumNew Stator bushings & sealing rings
dumModified Boost Valve Assembly
dumNew Boost Valve Spring
dumDirect / Reverse inout Drum
dumMachined surface for Maximum Band Performance
dumSpun balanced & checked
dumForward Clutch Housing
dumThoroughly checked & inspected Spline, Drum casting
dumUpdated / Modified Accumulators
dumRaybestos Pro Series Kevlar Ban
dumHigh-Temp. Tolerant
dumImproved holding power
dumAdded strength at Strut Support
dumUpdated & Modified Governor with Spring Kit and Nylon Gear
dumRecalibrated Valve Body
dumRecalibrated Valve Plate for Shift Firmness
dumNew High Flow Filter
dumNew Low / Reverse Heavy Duty Sprag
dumNew Heavy Duty Accumulator Spring
dumNew Modulator
Thanks Again... AB.
Also I keep getting asked how the shifter works and if its a "ratchet shifter" its not a ratchet shifter
Shifter wants too spring Left,
From "P" too "3rd"... "P"..Up Right & Straight Back too stop into "R". Springs Left & Straight Back too stop into "N". Right & Back 1 into "1st" choice #1 is Back one while springs Left into "2nd" OR choice #2 is Hold Right while Straight Back and into stop for "2nd". If #1 last used than Straight Back too stop into "3rd" If #2 last used than Left & Straight Back too stop into "3rd"...
From "3rd" too "P"...."3rd". Forward 1 into "2nd". Forward 1 into "1st". Straight Forward too stop into "N" springs Left & Straight Forward too stop into "R" Right, Straight Forward & springs Left & Back into "P"
There is no "Drive"
Fun shifter and works very well with the Reverse Manual VB.
Thanks, Adam
There is no "Drive"
Thanks, Adam
