LSx Dry Sump Setup (Dailey Engineering / Peterson Fluid Systems)
Category: Accessories
Price: $4500
Part Fits: 2010+ Camaro, Corvette, 04-06 Pontiac GTO, 04+ Cadillac CTS-V
Location (State): NY
Item Condition: Brand New
Engine: LS2/LS3/LS7/L92/LS9, LS1/LS6
LS Engine?: Fits LS Engine
Dailey Engineering 3 Stage Dry Sump Pump (Fresh from service at Dailey Engineering, 0 hours) Pump Mounts directly to the billet pan, no need for scavenge lines to the pump.
Dailey Engineering 3 Stage Billet Aluminum LS Dry Sump Pan w/ Two Brand New Drive Belts
GST Low Friction PTFE LS Rear Main Seal (Brand New)
Aluminum Breather tank with AN-16 Male Fitting w/
-Aeroquip AN-16 120 Degree
-Aeroquip AN-16 45 Degree
-Aeroquip AN-16 Stainless Hose
Steel AN-10 to LS Oil Galley (Short)
Aluminum AN-10 to LS Oil Galley (Long)
LS3 Valve Cover w/ AN-12 Welded Fitting for Peterson Crankcase Vacuum Regulator
Peterson Fluid Systems Crankcase Vacuum Regulator 08-0455
Peterson Fluid Systems 08-0010 - 3 Gallon Oil Tank Dual Scavenge Inlet w/ -Aeroquip FBM2170 - Aeroquip Reducers Fitting, Union Reducer, Male -16 AN to Male -12 AN, Aluminum, Blue
-Aeroquip FBM2170 - Aeroquip Reducers Fitting, Union Reducer, Male -16 AN to Male -12 AN, Aluminum, Blue -Peterson Fluid Systems 08-0101 Dry Sump Oil Tank Mounting Bracket -Peterson Fluid Systems 08-0101 Dry Sump Oil Tank Mounting Bracket
Peterson Fluid Systems 09-0452 - 60 Micron Oil/Fuel Filter with Bypass -12AN Fittings w/
-Peterson Fluid Systems 09-0400-027 End Cap Inlet -12 W/-10 w/ 1/8NPT PortT
-RaceGrade 1/8NPT Liquid Temp Sensor M 25-2197
-Aeroquip AN-10 Straight
-Aeroquip AN-10 120 Degree
-Aeroquip AN-10 Stainless Hose
XRP Inline Oil Filter Housing with Wiggins -16 Connections
ARP 234-2504 - LS7/LS3 Dry Sump 12PT Balancer Bolt Kit
ATI Super Damper Serpentine Series Harmonic Balancers 917279 w/ Dry Sump Drive Gear Inner Hub
You need -16 lines to hook this up depending on where you mount the tank. I can provide you with AN fittings or Wiggins clamps depending on how you want to install this.
