LS1 brake setup.
LS1 brake setup.
I have a 96 TA that I want to swap in an LS1 brake setup on. I need the
calipers, spindles, hubs, and lines for the E brake. I will be using new rotors,
pads, and brake lines. I may be doing this on two cars, so if anyone has two sets and wants to make me a deal, pm me here.
LS1 Brakes
I have a C5 Corvette, and the calipers on it are different
than the LS1 calipers I have seen. They are smaller in
size. Are these the calipers you have? I know they
will work with a bracket by reading some of the posts
in here. I thought the bracket was an after market
piece.
You just have the fronts? Let me know what you want
for the front setup. If I can find the rears cheap, we
might have a deal.
I know that with an after market rotor and pad, the LT1
setup will be just fine. I figured I'd go with an LS1 setup
while I was there, to shed a little weight.
Seamus
piece.
might have a deal.
Seamus
Originally Posted by Tim @ EADPerformance
I have two sets of corvette front calipers + brackets (they are the same as F-Body, just say corvette on them) also have two sets of spindles and hubs. I probably have the e-brake cables as well.
