rear QTR panel Drivers side have a ? for anyone. if you have a cheep one FS. if not how hard is it to pull on off. i know you have to drill the spot welds out but from the hatch to the door how do you get to them welds. |
I have a red one. pm me if your interested. |
i have a black one, 250.00+ shipping |
i can do it for 175 plus shipping. |
removal anyone how the hell do you get to the spot welds under the roof bar jobber. i think i can get it off and all. now i just need to know how the hell to get to all the welds. is there any trick in doing this |
i want to change mine out (i got a parts car) how would i go bout doing this wanyone? |
ya man. same here. reason being i started the thread. i guess this is a helper for all people |
anyone else know how to get these off really easy. |
its not easy. thats why people charge alot to do it generally. I explained it to you in my pm though. You have to drill out every spot weld along the seams. You have to remove the fberglass panel that goes across behind the t-tops. Its just glued on. So basically... remove the roof panel, drill out all the spot welds, weld new panel in. |
it was pretty easy last time i did it, i am fixing to put 2 on right now, you can split it without taking the top bonnet off right below it, thats what most people do , you can get a new quarter panel at gm for around 400.00 , the panel behind the t-tops is actually urathaned on and will need to be wired off with windshield cutting wire, takes 2 people and about 10 minutes , worst parts is driiling the old quarte panel off to make it look god enought to reuse |
where are you at? i'm in iowa and i've got one i'll sell reeeaaal cheap |
Originally Posted by camaromotorsports it was pretty easy last time i did it, i am fixing to put 2 on right now, you can split it without taking the top bonnet off right below it, thats what most people do , you can get a new quarter panel at gm for around 400.00 , the panel behind the t-tops is actually urathaned on and will need to be wired off with windshield cutting wire, takes 2 people and about 10 minutes , worst parts is driiling the old quarte panel off to make it look god enought to reuse I wouldn't say its really that easy for someone with no experience in wrecked fbodies/ repair work. The sail panel does need to be removed. You may as well do it right the first time and not splice that panels somewhere else. Make sure all the gaps are right before you tack the new on in. |
well i have both sides on another car. but that pannel (sail) between T-tops and hatch. i got some windshield wire to try to get off and didnt work. went to a local repair shop and they told me to cut along the angled area of the qtr right under the sail. weld a new in and clean it up with a die grinder. can anyone explain how the hell to get that top piece off. i would rather do that and not cut and shit. i would rather just drill spots out and pull off as a whole. |
i have the QTR available on another car. just how to go about getting it off is the question. how do i get the welds under the sail. how do i get the sail off. any suggestions. lemme know asap. thanks |
anyone please give some details on getting that sail off. |
© 2024 MH Sub I, LLC dba Internet Brands
