Notices
Need cam, push rods, oil pump, spring, install kit for LS1
Old 05-10-2007, 09:21 AM
ccajun4real's Avatar
Default Need cam, push rods, oil pump, spring, install kit for LS1
I need a new setup for LS1 (99 Corvette coupe). Decided to do cam rather than Nitrous and will be putting my Nitrous kit up for sale or trade for cam kit this week. Thanks
Cajun
Old 05-10-2007, 05:24 PM
00 Freak's Avatar
I have a stock oil pump if your looking for one. I wasn't sure if your looking a stock one or aftermarket. Asking $30+shipping obo. Thanks.
Old 05-10-2007, 05:55 PM
indianakid's Avatar
Default cam
for ls1 \grind number hr-228/353-2s1-12 (z-cam)
engine ident. 1997-up v-8 ls1
intake@353 @valve 600
exhaust@353 @valve 600 rocker ratio 1.70
all lifts are based on zero lash and theoretical rocker arm ratios
cam timing @ .004
opens closes advertised duration
intake 34.0 btdc 76.0 abdc 290.0 exhaust 80.0 bbdc 34.0atdc 294.0
spring requirements
triple dual outer inner
POWER RANG
3500 TO 6500 VALVES FLOAT AT 7100
loads: closed 137 lbs. @ 1.800 or 1 51/64
opens 347 lbs. @ 1.230
cam timing @ .050
opens closes max lift duration
intake 7.0 btdc 41.0 abdc 107 atdc 228.0
exhaust 53.0 bbdc (1.0)btdc 117 btdc 232.0
this is hole cam card
make an offer its brad new never used
what kinda nitrous kit you have please pm me for faster reply thanks
