Can someone check my IFR math for my 42lb/hr injectors?? Ok. The new flow rate for the 42's at 4bar is 48.6. 48.6/28.6 = 1.699 stock IFR values: 3.62 3.64 3.69 3.71 3.73 3.75 3.77 3.80 3.81 3.84 3.86 3.88 3.90 3.92 3.95 3.96 Multiplied by 169% new IFR values: 6.12 6.15 6.24 6.27 6.30 6.34 6.37 6.42 6.44 6.49 6.52 6.56 6.59 6.62 6.68 6.69 Is this right? Thanks. |
Re: Can someone check my IFR math for my 42lb/hr injectors?? looks good :cool: |
Re: Can someone check my IFR math for my 42lb/hr injectors?? that same slope is defnintely what you want but you may have to move your numbers into the mid 5's to get it rich enough for negative ltrims. |
Re: Can someone check my IFR math for my 42lb/hr injectors?? Dave, thats true, i had missed the pro-charger part of the sig. and im used to n/a stuff. |
Re: Can someone check my IFR math for my 42lb/hr injectors?? Thanks for the replys and the tip :cool: |
© 2024 MH Sub I, LLC dba Internet Brands
