can a bad o2 sensor cause lterm's to max im getting a code for p1133 for the drivers side front o2 and also the lterms on B1 are maxed out at 25 at idle could a bad o2 sensor cause the maxing out, or should i look for an intake or exhuast leak |
Re: can a bad o2 sensor cause lterm's to max I'm having a similar problem on bank 2, but not at idle, mine's periodic, is your car misfireing? |
Re: can a bad o2 sensor cause lterm's to max well i just installed heads and it is stumbling, not really misfiring though |
Re: can a bad o2 sensor cause lterm's to max the answer is yes i swapped the front o2 sensor and the car runs great |
Re: can a bad o2 sensor cause lterm's to max did u swap it just now?, so its fixed now? |
Re: can a bad o2 sensor cause lterm's to max the answer is yes i swapped the front o2 sensor and the car runs great joel |
Re: can a bad o2 sensor cause lterm's to max well the car was running like crap after i did the heads and i atapped it and it showed maxed out ltrims at idle on bank1 and a bank1 o2 sensor code. im was assuming the bad o2 sensor was causing the high ltrims and the running like crap so i swapped the o2 sensor and it runs like a champ havent atapped it yet, i dont have atap, a friend does, but ill probably log a few runs on tues |
| All times are GMT -5. The time now is 04:23 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
