LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   PCM Diagnostics & Tuning (https://ls1tech.com/forums/pcm-diagnostics-tuning-7/)
-   -   ls1 edit ? about o2's (https://ls1tech.com/forums/pcm-diagnostics-tuning/105581-ls1-edit-about-o2s.html)
Assassin Oct 7, 2003 05:47 AM
will I be able to turn off the rear o2 censors with ls1 edit, there for not need to get o2 sims?, wanna save the $ wherever I can,
and can u also change the speedo reading for different size gears? :cheers:
TILEMAN Oct 7, 2003 06:09 AM
Re: ls1 edit ? about o2's
yep, you can delete the rear O2s and calibrate the speedo for different gears with edit.
Assassin Oct 7, 2003 08:28 AM
cool thanks
© 2026 MH Sub I, LLC dba Internet Brands
