Reset FT's not allowing PE? finally have my VE where i want and the car running in SD perfect(+/-3) So i reset my FTs and i went to drive it for a highway pull and at wot from 2-5800 it is around 16-17.1, lastnight when i logged it was around 12.0-12.5.. my VE table has barely changed since lastnight. PE table is identical. Any ideas? |
TPS High voltage code pending? eg. did you grind on your bump stop? |
post the tune and log file |
Frost - the bumpstop mod i did a long time ago before the problems arose, maybe its going bad? i put a solid 120-130mi on the car tonight and its still not richening up.. the FT's should be learned by now. |
Originally Posted by 69LT1Bird
(Post 11784708)
post the tune and log file ill get them up tommorrow morn as they are on my other cpu. |
Also just looked in the car and i have 2 codes for "no input from 02 sensor" wonder if this could have something to do with it? |
post the tune and log! |
1 Attachment(s) log will be up shortly, i think i had a wiring issue, but here is the tune. |
p0101-p0103 MUST be set to fail on first (not 'no error reported') though you can leave the SES box unchecked. Give that a try before changing other areas, it may have actually kept you out of true SD. |
I just set them to MIL on first error, going out to log right now. |
1 Attachment(s) I think that was keeping it from going into SD. Heres the log, the 02 code is gone, and at wot it went 12.2 :nod: Frost, could you still look at my log and tell me how you think the tune is for the car? id greatly appreciate it |
You have LTFTs over 10% positive so you may have a little work left on the VE table here and there. |
| All times are GMT -5. The time now is 09:55 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
