O2 signal wire
O2 signal wire
I have a 98 lS1 trans Am. I'm looking for the O2 signal wire at the computer to hook up the a/f gauge, Dynotune air/fuel lean switch box? What color, what pin#, what connector. Thanks,
You are planning on using the narrowband for your a/f lean switch? You should use a wideband to be accurate at WOT. I posted in your thread on the Hptuners forum on how to hook it up.
http://www.hptuners.com/forum/showthread.php?t=25085
O2 signal
The LM-1 will not be staying on the car all of the time. I will be using the factory O2 for the Dyno-tune air/fuel switch to monitor it when sprayed. I just need to know the wire on the computer to hook into.
Using a narrowband for a/f lean shut off is dangerous being that it does not really read accurately where you are going to be at WOT...but see page 6 of this installation manual:
HSW Microedge Instructions
