Trust STFT's or WB for VE? 1 Attachment(s) I'm trying to go back to closed loop. I installed new ACDelco O2's and a new LM1 sensor also. I'm getting conflicting results in the HPT histogram. How do I isolate which to trust, and why the other sensor is not reporting similar fueling? |
I can't bring myself to trust the histogram, there is no differentiating between the "sensible" (steady state) and the "garbage" (transient throttle) and a street log is highly contaminated by the latter. I've been meaning to ask them if there's a way to filter for the same "steady MAP" criterion that is used to switch between MAF mode and dynamic airflow but haven't gotten to it. I bet the datum exists but don't see it, or delta-CylAir, as selectable PIDs meaning a custom one that spans frames, would be needed. Need a sense of history. Anyway, lies, damn lies and statistics. If you see a large (like several AFR units) difference between histo "+" and "-" views (min and max) then your data has too much noise to trust. So I kind of stick with doing it the hard way; take steady-throttle pulls, grab the snippet you really believe in, and work the table by hand with the real data, then feather it in (also by hand) to fit the un-touched cells to be smoothly continuous with the real. No automatic magic answer box, but I see a lot of guys keep going 'round and 'round that mulberry busy and never converging on the answer, because they're chasing a cloud of fog. |
| All times are GMT -5. The time now is 11:48 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
