LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   PCM Diagnostics & Tuning (https://ls1tech.com/forums/pcm-diagnostics-tuning-7/)
-   -   Intermittent PO327 - Knock Sensor, or could it be the O2's causing the problem? (https://ls1tech.com/forums/pcm-diagnostics-tuning/126117-intermittent-po327-knock-sensor-could-o2s-causing-problem.html)
demonspeed Jan 4, 2004 08:55 AM
My car randomly throws PO327. The light just comes on once and a while. Other times, it's never on. I've cleared it a couple times, and everytime I clear it, it comes right back. I'll drive it for a couple days, and it'll go out... and then it'll come back on sometime later.
I've been using Mobil 93 ever since I got the car, so the fuel is ruled out.
A buddy of mine suggested it might be my oxygen sensors are messed up and tripping the knock sensor code. Is this a possibility? I don't want to rip my intake out only to find the code is still there after I put new knock sensors in. Please help!
demonspeed Jan 5, 2004 10:13 AM
Anyone at all??
5550racing Sep 8, 2006 03:40 PM
TTT. :)
Anyone have any ideas? I'll get the code cleared, drive away, and it comes back on. Is it just a bad knock sensor? When I replace the knock sensor what else do I need? like intake gaskets? thanks
JustAnIlluzion Sep 8, 2006 03:44 PM
Originally Posted by 5550racing
TTT. :)
u dont need anything. but a good thing is to change the knock sensor harness also. i did my yesterday. my old harness didnt full engage the knock sensor which resulted in a low voltage code for that sensor. also u want to put some RTV around the top of the black boot with a opening in the back.
also its a good time to upgrade to a ls6 intake manifold :)
SPEEDYws6 Sep 8, 2006 04:29 PM
Change the knock sensors, if they are covered in oil you need to replace the seals in the valley cover. And like stated above about the silicone.
5550racing Sep 8, 2006 06:31 PM
Cool man, Thanks. I ordered 2 knock sensors, 2 harnesses, and the intake gaskets. I'll have to wait on the ls6 intake. :(
Would it be a good idea to pull the EGR stuff off while I'm at it? :suspiciou
© 2026 MH Sub I, LLC dba Internet Brands
