LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   PCM Diagnostics & Tuning (https://ls1tech.com/forums/pcm-diagnostics-tuning-7/)
-   -   Low Input on MAF...What's it mean? (https://ls1tech.com/forums/pcm-diagnostics-tuning/128055-low-input-maf-whats-mean.html)
1jfuddle Jan 10, 2004 11:11 PM
I'm getting an SES code that says low input on mass air flow circuit. What could be causing it? I just had a problem with an o2 sensor and threw a lot of codes. When I got the problem fixed and deleted the codes, this one stayed. Help.
wrencher Jan 11, 2004 11:55 AM
Low fequency input from maf, air leak, bad maf or sensor fuse popped.
All them o2 codes check the fuse first.
© 2026 MH Sub I, LLC dba Internet Brands
