What's this mean and is it bad? I heard of local tuners not adjusting the VE table. Was adjusting the injector table to compensate on a full head/cam /intake swap. |
That is not the proper way to tune... The injector tables should be set to match the installed injectors and then the VE and MAF tables should be tuned with a wideband... Anything else is a hack-job... |
^this. People USED to tune LS1 cars when they first came out that way... but its not understood that there are much better ways to go about tuning a LSx. |
thats fairly unwisetuning method, injector data is for the computer to know the correct injectors are in the system,your other tables such as VE are your adjustment tables for AFR and PE at WOT. |
Two wrongs always make a right. Yeah. |
Thanks guys I was just curious. I wish I had the knowledge to do the shit myself, but can be good at everything, lol... |
meh.... It is all air/fuel/spark in the end. Plenty of ways to arrive there. I wouldn't call it wrong, just a different way of doing it. Disclaimer: Yes, I adjust the VE table. |
| All times are GMT -5. The time now is 04:03 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
