LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   PCM Diagnostics & Tuning (https://ls1tech.com/forums/pcm-diagnostics-tuning-7/)
-   -   DTC'S HP Tuner's ? (https://ls1tech.com/forums/pcm-diagnostics-tuning/1395278-dtcs-hp-tuners.html)
JOSH13 Mar 8, 2011 05:37 PM
DTC'S HP Tuner's ?
Hey guys I have HP Tuners and cannot figure out how to remove these dtc's.
[Restraints] U1000 - Class 2 Communication Malfunction (History) (Immature)
[Restraints] U1016 - Loss of Class 2 Communication with VCM (History) (Immature)
I attempted to disable them but I do not know where to do so. They are not located with the other DTC's
:confused:
foff667 Mar 8, 2011 05:39 PM
Common when reading/flashing the pcm, they will likely go away after a few drive cycles without reading or flashing the pcm.
rnl35thss Mar 8, 2011 05:40 PM
I'm thinking you can only remove powertrain codes. The U codes are communication codes I believe. ^there you go.
JOSH13 Mar 8, 2011 05:42 PM
Oh that's strange. They popped up after I got my transmission back in and haven't found a way to delete them yet. I have re plugged in HPT several times though since then. No reason any of these would prevent lock up is there ? That's my current problem which I thought deleting these may fix.
JOSH13 Mar 8, 2011 05:43 PM
Oh ok thanks.
05HD Mar 9, 2011 12:49 PM
The codes are set in the restraints module (AKA SDM or DERM). It has nothing to do with your converter lockup nor can HPT or any other PCM tuning software "delete" them. Since they are both history codes as well, the problem (class 2 comm with the PCM) is currently not happening.
The restraints module communicates with the PCM to monitor things like vehicle speed and throttle position to save them in the event of an airbag deployment (the infamous "black box"). When that communication is interrupted by something, like you reflashing your PCM with HPT, these codes will set as a result. They go to history status as soon as you are done reflashing and the PCM gets back on the class 2 bus.
At first, GM wanted their techs to kill all of the other modules on the class 2 line by ungrounding them before beginning a PCM flash. Later, it was deemed unnecessary as the comm protocols were strengthened to ensure the flash was not interrupted by a polling module. These DTCs are a harmless artifact of that process.
© 2026 MH Sub I, LLC dba Internet Brands
