fuel trims at idle
fuel trims at idle
im workin on an 02 ss and having some pretty wierd idle issues. i can put it in open loop and it itles fine at about 14:1 afr..i put it in closed loop and the ltfts and stfts all go to like - 15 and it leans out to like 20:1 and goes to running like crap. clear the fuel trims and it goes back to running fine for a second till the fuel trims get back way negitive. it looks like both o2 sensors are working fine but the car has idled fine in closed loop before and i havent changed anything in the tune. i guess if no one has any insite on here im gonna repmace both sensors.. there is no cel or codes. thanks in advance
replaced the sensors no change. both banks got to like -15 in a hurry but it looks like the sensors are readin right like 13:1 afr is around 800mv and 16:1 is like 350mv..why is it pulling fuel
Slowhawk i didnt add many details because i was posting from my phone but thanks for the reply
Its a 2 bar speed density setup with 60 lb injectors. I looked last night i didnt save any good logs when i was working on this issue. I put it in open loop and everything is great. both o2 sensors are switching around stoich like they should. What else has influence on fuel trims? Both banks go to -15 in 20 seconds regaurdless of where the o2 sensors are reading. I replaced my wideband sensor just to make sure and its def lean...like 22:1.
I hope someone has some idea because im lost
Nothing has been changed that should effect this, afr command is 14:7 when it does this. Ive only changed VE PE the new boost enrich and both timing tables, Its a bone stock motor down to the valve springs
