idle timing? Do you set idle timing to what ever produces the most vacuum? |
Ideally that would be fine to do. But you will loose under speed spark correction by doing that. Fine best vac and wind it back enough to allow spark control to work |
What is your set up? |
Under spark correction?
Originally Posted by Higgs Boson
(Post 15352532)
What is your set up? AFR 225 235/239 113 LS6 intake 1.75" headers |
I would find the best spark position, then take out 5 degrees and give it to the underspeed table like macca says. That table is messed up in some years, check it and make sure it's not set to "give up" at high underspeed. |
Originally Posted by STAR
(Post 15357594)
Under spark correction? 408ci AFR 225 235/239 113 LS6 intake 1.75" headers my spark cells and around it are at 29 and the over/under and correction tables are stock. make sure your ve is spot on, your timing table is smooth and if you are trying to run closed loop expect it to over-fuel at idle. i run open loop only. |
(Post 15346920)
Do you set idle timing to what ever produces the most vacuum? When the idle spark is set at maximum vacuum (or lowest kPa) it is hyper-sensitive to any change in fuel/air/spark which makes it difficult to achieve a smooth idle. |
Originally Posted by Mez
(Post 15362502)
No. You set advance a ~5 degrees less than maximum vacuum (or lowest kPA) to give the idle spark over/under speed correction tables enough range to do their job. When the idle spark is set at maximum vacuum (or lowest kPa) it is hyper-sensitive to any change in fuel/air/spark which makes it difficult to achieve a smooth idle. |
Good ole spark correction! I found that my car made the mount vacuum with stock idle spark tables. So it deffinetley varries 236/240 cam |
© 2024 MH Sub I, LLC dba Internet Brands
