MAF, H2O's, & VATS
Old Sep 11, 2011 | 03:22 PM
Joshua8336's Avatar
Default MAF, H2O's, & VATS
how do i tune these out?
Old Sep 11, 2011 | 04:35 PM
cyipher's Avatar
Well first your gonna need a particle accelerator to be able to split an atom, at this point you can split the H2O atom into to its 2 parts hydrogen and oxygen together this will burn off at a rapid rate once a acceptible ignition point is supplied.
on a more serious note what are you using efilive or hptuners?
Old Sep 11, 2011 | 04:49 PM
Joshua8336's Avatar
i ain't using nothin right now, i'm askin what i need to tune it out... which is easier to work with?
Old Sep 11, 2011 | 05:41 PM
cyipher's Avatar
Hp tuners is easier to use, however if you dont plan on a lot of changes for your car in the future you may just wanna find a tuner local to you who can turn off those codes.
Old Sep 12, 2011 | 06:17 PM
Joshua8336's Avatar
iaght, i'll look into it, thanks alot!
