LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   PCM Diagnostics & Tuning (https://ls1tech.com/forums/pcm-diagnostics-tuning-7/)
-   -   LS1 with BS3 won't start (https://ls1tech.com/forums/pcm-diagnostics-tuning/1481070-ls1-bs3-wont-start.html)
1point3liter Oct 27, 2011 09:31 PM
hey guys, I'm having some trouble getting my LS1 to crank with a new BS3 install. I've tried with a crank reference of 350, 355, 360, and 370. I have spark and fuel. I put new plugs in tonight. After laying on the key for a little bit it'll sometimes try to hit a little bit, but never quite fires off. I did a BAL and i'm getting a grey dot while cranking. In the IO Status screen I'm usually getting some "bad sync" events. I searched through the manual, on google, on here, and other forums and can't find any info on the bad syncs. Sounds like it may be an indicator of the issue. Any ideas?
Also, one weird thing i noticed, my TPS won't ready more than 55% or so. i pulled off the sensor and did a sweep lock to lock sweep. still 55% give or take. I haven't had a chance to put a multimeter on it yet. I don't see this affecting my start-up though. i set the flood control to 30% throttle temporarily.
:bang:
MIGHTYMOUSE Oct 28, 2011 10:05 AM
ls2 cam sensor, swap the wires?
Brad Campbell Oct 28, 2011 10:36 AM
If the wiring for the sensors is messed you could be pulling the 5-volt source down thus only having 55% scale on the tps. I don't remember the differences pin to pin. Just a thought.
1point3liter Oct 28, 2011 10:45 AM
It's a ls1 engine. I'm not familiar with the ls2 sensor. Will a ls2 sensor fit in the ls1 block behind the intake? I can check the part number when I get home.
MIGHTYMOUSE Oct 28, 2011 11:54 AM
where did you get the big file you are starting with?
i can send you one i was running on a bone stock ls1 if you email me mightym0use@verizon.net
but that wont make the ball turn green, thats an electrical connection somewhere.. i think
1point3liter Oct 28, 2011 01:00 PM
I saved the cal out of the BS3 when i first hooked it up.
Im pretty sure the ball turns green, but i can check when i get home.
The other dot that shows up after pressing the B A L keys turns grey while cranking Is it supposed to turn green too?
1point3liter Oct 28, 2011 01:01 PM
Thanks i'll double check the TPS wiring when i get home.
MIGHTYMOUSE Oct 28, 2011 04:03 PM
why a ford tps?
1point3liter Oct 28, 2011 04:20 PM
I have a ford throttle body. Everything is in a rx7.
MIGHTYMOUSE Oct 28, 2011 04:24 PM
sent u a file to try
just in case you didnt know, bs3 take a while to fire up
1point3liter Oct 29, 2011 02:27 PM
Problem solved. Bad map sensor!
Also, the tps was only reading 3.8v at wot, replaced it too.
Thanks for map mighty mouse.
MIGHTYMOUSE Oct 29, 2011 02:48 PM
cool man, hope that file gives you a good jump start
© 2026 MH Sub I, LLC dba Internet Brands
