750 ohm 1/4 watt resistor Does anyone know about how many degrees this baby will retard timing? |
Um what car? What year? What engine? What sensor do you plan on putting that in between? |
94 LT1 . I think it plugs in to the MAF in the same way the cheap boxes you get off of EBAY, tells it is the temp is hotter rather than colder. I actually don't plan on using it. I was just curious. I have tuner cat and ALDL cables to suit my needs. I might build a resistor box though as a contingency. |
© 2024 MH Sub I, LLC dba Internet Brands
