LC1 Wiring question.
Old Feb 8, 2012 | 06:59 PM
Revson's Avatar
Default LC1 Wiring question.
Hoping someone could help me with this. Bought a second hand unopened LC-1. Went to set it up today and it looks like in the instructions that there should be 7 stripped wires. Mine only has 5, with 2 the green and brown, going into a 4 prong connector. Is the connector supposed to hook up to something? Ir should I just cut it off and strip the wires so it matches the instructions? Pic of connector below.
Old Feb 22, 2012 | 07:23 AM
UKDriver's Avatar
There are two versions of the LC1 (old & new) . One had 5 the other 7 wires - can't remember which was which.
Here's how I connected up the 1999 Vette for narrow band simulation and HP Tuners logging.
File Type: pdf
Old Feb 22, 2012 | 08:01 AM
Revson's Avatar
Thanks for the info! Mine has the seven wires, just 2 of them went into the connector in the pic. I ended up just cutting that connector off and wiring it up as per the Innovate instructions and it works fine. No idea what the connector was for.
I am wiring it my 99 Vette soon, but I am going through the rear O2 senor bung, as I'm not running cats. Then I will read it in HP tuners by running it through the PCM, using the egr pin out, since the Vette doesn't use that.
