02 readiness still won't clear 04 GTO PCM. I've got all o2 realted DTCs set to No Error Reported, from P0131 to P0167. Yet I can't clear it. Do the SES Enable all need to be unchecked too? I don't get any DTCs or a CEL and I've driven plenty of drive cycles and reflashed recently twice and yet I can't clear it. Readiness shows not ready even with my generic ebay scanner. Thanks, Frank |
The MIL enablers have to be set to MIL... |
Originally Posted by BLK02WS6
(Post 16169079)
The MIL enablers have to be set to MIL... http://www.mde.state.md.us/programs/...%20Website.pdf Frank |
I have seen many GM OE calibrations that have the readiness set to pass when the PCM is on the bench. I have seen a stock XLR-V's with the cat DTC's shut off and the emissions monitor displaying PASS for the Cats. If GM is able to do it you should be able also. The only issue would be the Tuning Software. send me a copy of your tune and I will take a look at it caleditor@pcmcalibrators.com |
Sent. Added all "SES Enables" that were not checked for the O2 section of DTCs and still get 02 readiness not ready. Below is my DTC file save. No DTC's Detected Continuous Tests Misfire: Complete Fuel System: Complete Comprehensive Component: Complete Once Per Trip Tests Catalyst: Complete Heated Catalyst: n/a Evaporative System: Complete Secondary Air System: n/a A/C System Refrigerant: n/a Oxygen Sensor: Incomplete Oxygen Sensor Heater: Complete EGR System: n/a |
I think you will understand |
(Post 16169079)
I found this works (for me, using EFILive): All the DTC's related to a readiness test need to be set to Not-Reported with MIL enabled (see Service Manual for each readiness test's listed DTC's). For a Not-Reported DTC, if the MIL is enabled the test immediately "runs" without reporting an error; when all the DTC tests for a readiness have "run" (regardless of test results), the readiness test becomes ready; if the MIL is disabled for a Not-Reported DTC, the DTC's test is not "run"; one or more not-run DTC tests prevent the readiness test from becoming ready. |
1 Attachment(s) He had it set like that Joe Attachment 348604 |
Originally Posted by joecar
(Post 16172632)
I found this works (for me, using EFILive): All the DTC's related to a readiness test need to be set to Not-Reported with MIL enabled |
I'll get out there after a few cups of coffee and the laptop charged and flash the latest per CalEditor (afte checking out my file) with SES unchecked and see what's up. I had darn near everything set to "No Error Reported" but did have SES enable all checked. |
If it changes to N/A let me know and I will come up with another plan |
2 Attachment(s) No dice with them turned off. Flashed with them off. Pulled DTCs and saved, read PCM again to make sure tune wrote properly. I also noticed that my EVAP gets a complete with SES enabled and "No Error Reported" and my EGR and Secondary Air get an N/A with "SES NOT Enabled" and "No Error Reported". Does that mean that the readiness will not complete with SES NOT ENABLED which seems to be what BLK02WS6 alluded to? |
Let me see how GM did it and I will post back shortly |
Thanks. This PCM was a bit screwy when I bought it a few years ago. I could not fix issues with the speedo section (in hptuners) so I had to compare it to an almost stock GTO, and copy over the differences from that file to mine, then change it again and it saved. Apparently you can't compare DTC pages from two tunes and copy over though. I don't see the Engine Diag in the comparison log file when I compare mine to another GTO tune. |
4 Attachment(s) Stock O2 settings Attachment 348646 The way I set it up with the Boxes Checked Attachment 348647 Your Settings Attachment 348648 You need to change these to Type 3 and then it will pass on the bench Attachment 348650 |
Yeah, you have to change all the O2 codes to get it to be ready. |
Originally Posted by JonCR96Z
(Post 16174708)
Yeah, you have to change all the O2 codes to get it to be ready. I'm at work now away from the laptop so I'll check tonight when I get home. Thanks, Frank |
So I'm an idiot. Totally missed the second section of DTCs for HO2S that CalEditor showed in his post. Changed them and flashed and am good to go. I feel like a big dummy. Part of the downside to using a netbook to run HPtuners. When I paged down on the DTC page I must have blown right by the second section. (I have to make some excuse other than my own stupidity). Thanks again, Frank |
| All times are GMT -5. The time now is 10:17 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
