LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   PCM Diagnostics & Tuning (https://ls1tech.com/forums/pcm-diagnostics-tuning-7/)
-   -   Won't shift 2-3 when it hooks (https://ls1tech.com/forums/pcm-diagnostics-tuning/1576507-wont-shift-2-3-when-hooks.html)
Tan327 Aug 19, 2012 04:03 PM
Having an issue with my car and I'm 99.9% sure it's the tune. When the car dead hooks at the track it hits the limiter going to 2-3, but if it spins a little it will shift just fine. It will also shift fine from a roll. A friend of mine said that he has heard of this happening when cars dead hook, any recommendations? I may be able to get a copy of my tune posted. Thanks.
flame Aug 19, 2012 04:59 PM
You've got a few options: lower the shift mph/rpm, raise the limiter, add trans pressure. Either way as long as the trans isn't toast you can fix it with tuning.
BLK02WS6 Aug 19, 2012 06:59 PM
And if you keep lowering the shift points, and it keeps hitting the limiter, you need a tranny...
dodson55 Aug 20, 2012 02:45 PM
a 4l60 with no third gear shift my bet is the tranny that is what happens to 99% of them
© 2026 MH Sub I, LLC dba Internet Brands
