LM-1 and IAT/CLT tables
Old 01-30-2013, 07:50 PM
Bigtoyz's Avatar
Default LM-1 and IAT/CLT tables
Well finally got it figured out how to get it setup.
Once you click on the Custom Lookup Table
Click on Thermistor Temp Sensor and it will bring up a new page.
Within that page is the info you will need to input.
Temperatures in: Celsius is checked and Resistance in kOhm is checked
In the Desidred Temperature Range
-40 to 150
Sensor is connected on one side to:
is set to +5 volt
Resistance/Temperature Celsius
100.700 at -40
.973 at 50
.047 to 150
Load Resistor Size
is .0172 kohm
for note I went into Autotap is what I use and found out what temp the IAT was showing which was in Farhenheit. Mine at the time was showing 80 DegF.
That converted to DegC is 26.67. How I came to Load Resistor Size of .0172was trail and error till the gauge read 27 DegC and it bounced between 27 and minus a little.
But you can double check it on your setup just to make sure but should get you really close.
Quick Reply: LM-1 and IAT/CLT tables
