Car won't start
Old Apr 23, 2013 | 07:27 PM
Orange Juice's Avatar
Default Car won't start
Car will start run briefly then quit. It has been sitting up at a transmission shop getting some work done when this happen. I need to get the car started and back home. I understand that disableling the "Vats" is one way to get around the security system but I don't know where to find this on HP tuners.
Any help would be appreciated.
Old Apr 27, 2013 | 12:44 AM
rickus54's Avatar
I have same problem with 2002 z-28. manual trans. Had dealership change key and locks. changed clutch safety switch. Tried to reprogram security system. have to push start it all the time. Help
Old Apr 27, 2013 | 03:12 AM
rickus54's Avatar
why does not ls1 motor start up,except push start battery, clutch switch ignition key help
Old Apr 29, 2013 | 10:50 PM
kvrL33's Avatar
Could also be a grounding issue. You could check all the grounds on and around the battery. They may have disconnected the battery if they worked on your car. Just an idea.
