- - evap system won't reset
(https://ls1tech.com/forums/pcm-diagnostics-tuning/1641879-evap-system-wont-reset.html)
f355bird
Apr 24, 2013 09:42 AM
I had some codes that I fixed and now after a 1000 miles my evap system still has not reset anyone have any ideas? All of the other readiness monitors are reset and no codes.
sicksspeed
Apr 24, 2013 11:24 AM
only thing i can tell you is that evap is the hardest to reset. requires cold starts and corect conditions.
Ed Wright
Apr 25, 2013 12:14 PM
Originally Posted by sicksspeed
(Post 17344283)
Yes, and the Corvettes seem to be the worst. Cold start temps, at what steady MPH it is driven and how long that has to be one since a cold start in the temp range they specified, etc. I had to change the conditions for the test to run so we could get one customer's vehicle through the smog lab in AZ. Been a week since the battery was hooked back up and it was driven over 1000 miles to get there, and still had not run that test. We got it to run finally. The vehicle has to be submitted for testing with the tests run and the flags set to Pass. Then they clear them before putting it on the rollers, and has to run and pass most of them all over again. About everybody has trouble getting the Corvettes to pass EVAP for some reason. GM set some strange conditions for the test to even run. I didn't change what it took to pass, just what would get it to run the test.
f355bird
Apr 25, 2013 03:54 PM
Thanks for the info I guess I will just see what happens. Since my car is a 98 here in texas I only have to have 6 out 8 ready and I have 7. Glad I'm not in a tougher state.
