lq4 questions Putting an lq4 in my 02 z28, which harness and pcm should I use? I will also need some 32+lb injectors, which are the best budget ones to run to be compatible with whatever harness I need? Thanks |
use the harness and pcm from the Z28. L67 injectors are cheap |
© 2024 MH Sub I, LLC dba Internet Brands
