LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   PCM Diagnostics & Tuning (https://ls1tech.com/forums/pcm-diagnostics-tuning-7/)
-   -   quick question about O2's... (https://ls1tech.com/forums/pcm-diagnostics-tuning/166317-quick-question-about-o2s.html)
Z'mnypit Apr 29, 2004 03:53 PM
i just scanned my car and I had 2 left bank 1 lean codes.. Also a low voltage O2 sensor code...This also happens to be the same O2 my a/f gauge is hooked to.. (It isnt working any more It want read any bars) I replaced it with one off the rear i had b/c of 02 sims.... still gives the same code... My qustion is how can I fix this? i allready check the engine sensor fuse its good... :huh:
Z'mnypit Apr 30, 2004 10:19 AM
tttttt........
horist Apr 30, 2004 10:33 AM
check to make sure the wires aren't melted?
Clear PCM, install new O2 ... drive car around and see if the O2 is still reading lean and setting a code
If so then It's most likely wiring somewhere..
Check where you tapped the wire for your A/F gauge... this may have gotten corroded or come apart
There's an extension on bank one that goes up towards the top of the car
(so it's O2 sensor plugs into extension (comes w/car) plugs into another harness) disconnect this and ohm test it to make sure it's not dead
But my guess would be a problem where you tapped into the O2 sensor for your A/F gauge
Z'mnypit Apr 30, 2004 12:00 PM
Its fine where I tapped into the O2 sensor.... I have checked the plug with an ohm meter... Its not dead... I havent checked the wires being melted... I almost bought a new 02 sensor but I didnt b/c I didnt know if the 02 was bad or not....
horist Apr 30, 2004 12:03 PM
hmmm... maybe try swapping both front O2s and see if hte problem follows the sensor?
If it doesn't and you're confident w/the wiring ... then it would be a fueling issue I think?
Maybe a clogged injector on that side of the engine?
Z'mnypit Apr 30, 2004 12:11 PM
Ill double check the wiring but I pretty sure its ok... Ive tried swapping 02's around and still the same problem... The a/f gauge will work sometimes @ WOT but it want read past lean.... I pulled the plugs and all the ones on the left bank are a whitesh color so I know its running lean, that could be whats worng with my gauge.... What should I try first?
horist Apr 30, 2004 12:19 PM
damn they're all showing really lean? I'd look at the injectors but not really sure...
There are some places that will do an injector cleaning ... or run some techron injector cleaner through a tank....
but if it's runnig that lean i'd be worried about driving it long
Was anything changed before this started happening?
Z'mnypit Apr 30, 2004 12:24 PM
Headers....
horist Apr 30, 2004 12:36 PM
hmmm... can you post up your autotap logs? Specifically...
Log
TPS
RPM
Bank 1 O2 sensor 1
Bank 2 O2 sensor 1
LTRIM bank 1
LTRIM bank 2
Fuel Trim Cell
Z'mnypit Apr 30, 2004 12:39 PM
I dont have an autotap... I was using and OBDII scanner..... It just started out of the blue I was driving then all of a sudden it started missfiring, then the gauge quit working, and it started throwing the lean codes & low voltage on 02 left bank 1...
ataylors Apr 30, 2004 01:03 PM
disconnect the gauge
Z'mnypit Apr 30, 2004 01:30 PM
What will that do?
ataylors Apr 30, 2004 01:32 PM
maybe there is something shorted or grounded in your gauge.
Z'mnypit Apr 30, 2004 01:38 PM
If there is something grounding out with the gauge, Will that richen up the left bank ?
Z'mnypit Apr 30, 2004 07:44 PM
Ok I put all brand new plugs in.... Changed the 02 sensor(not a new one just replaced with one of the rears I had @ my house), Cleaned the mass air sensor, checked all the wires all the way to the pcm from the 02 sensor... Checked all plug wires... & my gauge still want work & its still surging & misfiring & running lean on the left bank....... SOMEONE PLEASE HELP!!!!!!!!!!!!!!
horist Apr 30, 2004 08:01 PM
did you try disconnecting the gauge like ataylor mentioned? Sometimes the simplest solution is the best (the gauge may be shorting out internally)
Z'mnypit Apr 30, 2004 08:20 PM
Yeah its sitting in my floor right now....
ataylors Apr 30, 2004 09:36 PM
what voltage does the O2 show??
maybe your gauge broke your PCM
SSmokin 01 Apr 30, 2004 09:47 PM
How is it hooked up. At the PCM, O2 extension with A/F wire pre-installed(casper electronics), spliced into O2 sensor harness?
© 2026 MH Sub I, LLC dba Internet Brands
