Injector vs. Voltage Offsets
3bar SD open loop dyno tune on motor currently.
Tune was done with a crappy old alternator, and I would assume very low voltage.
Few weeks after dyno tune, I installed a new high output alternator, and now header primaries are glowing at idle.
Related?
Related?
I do not think its mechanical cause I have good vac at idle and both banks are doing it not just one primary or two.
The tuner seems to think it is mechanical and I will pull a plug this afternoon but any ideas here or things to toss past the tuner? I think a 2 volt change in system voltage would change injector offsets but I dunno tuning stuff.
Moderator
Whether your headers "glow" depends somewhat on
the viewing conditions as well as the fueling. I've
seen chromed headers glowing with a decent idle
mixture, with the shop lights off. Lights on, you
wouldn't notice.
I do not see any actual AFR readings reported so
it's hard to say anything useful.
wouldn't notice.
9-Second Club
Some "tuners" pull the timing way back at idle to stabilize idle RPM. That certainly makes for red pipes. That is dumb as hell. One well known tuner asked me once why I thought he was seeing so many hot headers. He was using something like 10 to 12 degrees at idle, and zeroing out the idle speed correction spark tables because he didn't like to see the timing move around at idle. I told him it was the late timing at idle. He pretty much told me he thought the timing no stable at idle was just wrong, and there had to be another cure.
If your not seeing knock retard at idle (a tuning issue ) or a screw up in a temp correction table, it was likely the tuners choice. Alternator won't do it.
