98 LS1 Wiring Harness Question (C100 Connector.. TPS Wires...)
Scroll down to the end of the post for a one sentence question if you don't feel like reading any background story...
So I'm tearing apart a 98 LS1 fbody harness to weed out emissions wiring, repin for 99+ PCM, and to relayout the harness in a swap application.
I have it all torn down to the injector and coil sections, and individual runs of sensor wiring (maf, map, O2s, etc.).
I have run into one "issue". I can't wrap my head around why the run of 3 TPS sensor wires does not lead straight from the TPS pigtail to the PCM. Each of the 3 TPS wires Ys off; one lead leading to the PCM and one lead leading to the C100 connector that normally rests above the wheel well on an fbody.
I can not find a wiring diagram to see where the 3 TPS wires run on the chassis side of things once they are past the C100 connector.
What would they be running to on a 98 fbody??? Do they run from the C100 to the engine bay, or the cabin? Traction control maybe?
This is just bugging me because it's the only thing I don't have worked out in my head. I *believe* I should be fine running the 3 TPS wires straight to the PCM. I can't think of any other system that needs to know what the throttle position is besides the PCM.
Im just trying to save myself some time, I would hate to wire the TPS straight to the PCM then realize "Oh hey yeah I should have ran those TPS wires running to the C100 connector to the xxxx.).
[In short]
Will the 3 TPS pigtail wires be fine running straight from the TPS to the PCM on a 99+ fbody PCM, or do they need to Y off before they enter the PCM and run somewhere else in parallel?
[In short]
Yeah I do, they don't show the tps wires running to anything else besides the pcm/ tps.
Oh well, I decided Im going to run the TPS wires into the cabin anyhow. Along with a spare power, ground, and tach wire and a few extra wires to keep an open door for nitrous, etc.
Im just curious why they had TPS wires running into the cabin from GM. Only thing I can think of is it was for cruise/ traction control, but I don't think either of those need TPS. I admit I didn't check out any traction control/ ABS schematics since I have no ABS and an aftermarket cruise control setup tho.
