Need help with idle surge/hunt tune and log attached. 2 Attachment(s) I attached the tune and idle log, idle surges up and down a little in park and neutral but when you but it in gear it really hunts up and down. E85 127lb injectors 390 4000 stall 4L80 the wideband is ngk and only has the gas scale, that's why it looks like it has gas afr's. Thank You |
* Start off by setting your idle ignition advance to mid 20s. * Make sure your idle>in drive and idle>in park tables match and that they also match your high octane table up to 1,200 rpm or so. Needs to blend seamlessly from idle tables to high octane table. Your huge step from 19° to 30° between 800 and 1,200 rpm in the idle tables is probably causing most of the problem. Get those 19° tables up 6 or 7 degrees and blend into the high octane table. * Idle Underspeed Spark vs RPM Error is too aggressive. Take out half or more in the -25 to -250 fields. * Idle Overspeed Spark vs RPM Error is better but could be reduced a little from 50 to 200. * Injector Flow Rate vs KPA VAC - set at 127 all the way across... Do you have a boost referenced fuel regulator? * How comfortable are you with the injector flow data? * I'm a little suprised to see you don't carry the PE table out past 3,600 rpm. Even with an enhanced OS boost table most folks set the PE table and use the boost table as a backup. The way I understand it is slower to react than the PE table. *Base Running Airflow>Idle Airflow - I assume you have scanned and set this table appropriately? * Primary VE - What's up with all the peaks and valleys? Lot's of room for improvement with some smoothing. Maybe some of these comments will help with your idle surge. I typically work on smooth ignition idle tables and then look at idle airflow. |
chevy 406 thanks, yes boost referenced, smoothed the timing tables and is getting better, still needs work. |
Boost reference is good but I do not use the vacuum reference. Have found it to affect idle too much.Can cause surging ect. |
Originally Posted by Slowhawk
(Post 17971191)
(Post 17971191)
Reference it before the throttle body. The side port next to the cable works good. |
1 Attachment(s) I have my HP Tuners usb stick with me today so I did some copy and paste to your tune in the VE, timing and idle areas. This might not exactly work for your particular setup, but it may help get you closer. |
(Post 17971346)
Originally Posted by Chevy406
(Post 17971353)
(Post 17971191)
© 2024 MH Sub I, LLC dba Internet Brands
