PLX wideband install with hp tuners. HELP!
Ok guys this is my first experience with tuning using a wideband.
So I just bought a PLX m-250 used. complete
http://www.plxdevices.com/Installati...UsersGuide.pdf
So what im confused on is- In the instructions, is the white wire the one I would plug into the IO connector on the HPtuners box?
Currently I have that wire going to my gauge and everything is working.. If the white wire is the correct one, could I splice into the white wire so its still going to the gauge and then also to the HP tuners box at the same time? or does it have to be one or the other?
Correct me if Im wrong, im a newb at this.
yes, you can "T" or splice the white cable that goes from the gauge to your input hptuner slots..
so the white cable would go to the gauge and then another cable T'd off would run to the hptuner box
