LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   PCM Diagnostics & Tuning (https://ls1tech.com/forums/pcm-diagnostics-tuning-7/)
-   -   Dumb Question: How do you delete the rear 02's using LS1Edit? (https://ls1tech.com/forums/pcm-diagnostics-tuning/170787-dumb-question-how-do-you-delete-rear-02s-using-ls1edit.html)
McRat May 12, 2004 11:19 AM
Which area of the program do I use? Is it the "Hardware Diagnostics?"
Any help would be appreciated.
Team ZR-1 May 12, 2004 03:05 PM
FYI,
you are not deleting or turning off the O2s,
you can only turn off any DTC errors they can trip on via as you metioned the diag section so that the PCM does not trip SES light or store the DTC code
felton316 May 12, 2004 05:19 PM
Hardware diagnostics. Find the code you want turned off and set it to 'Type=X'. Like Team ZR-1 said, you are not turning the O2's off but just telling it not to display the code.
McRat May 12, 2004 07:19 PM
Thanks!
I'll give it a try tonight.
Nickn20 May 12, 2004 08:54 PM
P0137, P0138, P0140, P0157,P0158, P0160 are the most common ones to go off. might as well turn all those off while your in there.
bob1esq Aug 30, 2004 09:06 PM
Thank you Nick--I couldn't figure it out either.
2xLS1 Aug 30, 2004 09:46 PM
P0137 HO2S Circuit Low Voltage Bank 1 Sensor 2
P0138 HO2S Circuit High Voltage Bank 1 Sensor 2
P0140 HO2S Circuit Insufficiency Activity Bank 1 Sensor 2
P0141 HO2S Heater Circuit Bank 1 Sensor 2
P0157 HO2S Circuit Low Voltage Bank 2 Sensor 2
P0158 HO2S Circuit High Voltage Bank 2 Sensor 2
P0160 HO2S Circuit Insufficiency Activity Bank 2 Sensor 2
P0161 HO2S Heater Circuit Bank 2 Sensor 2
P0420 Catalyst System Low Efficiency Bank 1
P0430 Catalyst System Low Efficiency Bank 2
© 2026 MH Sub I, LLC dba Internet Brands
