How to run open loop? I need to know how to force the car to run open loop all the time? I dont want to run a MAF anymore or deal with O2 sensors. I'll be getting a wideband soon for tuning. Just need to know how to keep the car in open loop. Also once in open loop, can i just use the VE table to tune rich or lean? When in open loop what tables are no longer used and what tables are still used? |
Set the Cold WOT and Hot WOT to zero for all RPM ranges. |
Originally Posted by bomax Set the Cold WOT and Hot WOT to zero for all RPM ranges. Go to the -> Eng Cal->Fuel->Closed Loop Enable Temp, set all cells to 180*C. Now it will stay in Open Loop until 320*F. Open loop - F/A Multiplier, IFR, VE and PE tables all apply. You will probably need to calculate a new VE table. FWIW. joel |
Once in open loop, can i tune it with the PE table still or just the VE table? |
© 2024 MH Sub I, LLC dba Internet Brands
