best OE ECU for standalone/tuning
Hi
im swapping a lq4 into a 2gen rx7 and was trying to figure out what would be the best ecu to use for the swap and subsequently tune later (HP tuners). i've heard alittle bit about 00-02 ls1 fbody ecus are one of the favorites for using with HP tuners.
the setup in the car is:
lq4 long block
ls7 cam
36lb injectors
pro china intake manifold w/ 85mm tb
t56
Basically i just need the ecu to run the engine and possibly the t56 shift lockout stuff. fuel system and gauges are going to standalone on their own circuits
thanks
the car is also not emissions compliant, so egr control is not needed.
lq4 long block
ls7 cam
36lb injectors
t56
thanks
