3 Bar HP Tuners What ECUs work?
Turns out my ECU Can only be flashed to a 2 bar map. I emailed HP Tuners support and they cant tell me what ecus will work. I am looking for an 04-06 ECU that is 3 bar capable. I can confirm that my ECU
VCM OS ID 12613248 cannot be flashed to 3 Bar. It came out of an 07 GMC Van with the older style ecu.
Does any one have a known good ecu so I don't have to play russian roulette at the junk yard
I know my ECU OS will not work. The car is wired to a blue green harness, Id rather not repin it. I am asking if anyone has a know OS that can be upgraded to 3 Bar since apparently HP tuners tech support doesn't know.
The newer PCMs have very few Operating systems which are 3 Bar capable.
Your best bet is to get a 03-05 OS with 3 Bar capability that can run all the systems in your car/truck (trans/cluster/fuel gauge/etc).
I have a few files you can flash to your PCM. Post your current stock tune to check options. Give more details about your ride. Is it a swap or what?
I have a 2005 Silverado stock tune for a 6.0L with 4L80E and DBW, I confirmed it can be upgraded to 3 Bar. You can flash it directly with Hptuners, no Tech2 needed.
If you are interested, I can upload it.
