is it possible to check the ground signal that triggers the fans?
long story short i have wiring/cooling issues. Both fans are turning on at the same time or the one signal is turning on both or vise versa....really i have no clue whats going on. Is there a way to test the 2 wires coming out of the pcm to see when they are giving off a signal to turn the fans on/off? Being ground switched, i dont know how to check that. Or could my pcm be screwed up and grounding out making the fans not work right?
PWM? Don't know what that means. There Derale fans, I had them wired but the fuses got too hot and started to melt. Rewired them today with new fuses holders and ran thicker wire but they are not working like there supposed to and blowing fuses. Being ground switched, am I supposed to wire them differently?
Without seeing a schematic of what you are trying to do it will be impossible to help. I hope you are still using relays of some kind. Stock wiring uses 2 outputs with 3 relays to either configure both fans in either series or parallel. The PCM cannot drive fans directly with its ground outputs. It can only drive relay windings.
So back to this crap. I rewired both my fans last night on completely 2 separate circuits. Each fan has its own power, ground, relay, fuse etc., however when the low temp signal kicks on for the first fan, both of the fans turn on, on top of that the high temp fan kicks on a second before the low temp fan turns on. How the hell is that possible? It was all working fine the few hundred miles iv been driving it, then I blew a fuse due to too small of wire (14g) feeding the fans that led to the rewire with 12g. After the rewire the fans have been wrong.
