Tuning base running airflow
Old Feb 6, 2015 | 10:35 PM
VandykeT/A's Avatar
Default Tuning base running airflow
I've searched and I find several different methods for doing this but some will say this was didn't work or this didn't. Can someone point me to a accurate explanation of how to tune this table? What do I need to make a histogram of etc. sorry for the dumb questions
Old Feb 6, 2015 | 10:53 PM
JakeFusion's Avatar
Super Hulk Smash
Log with this file (had to ZIP - forum won't allow cfg file uploads). Do not touch your throttle. Do it from a cold start. The histogram will populate automatically.
Do it in park/drive and with a/c on and off.
File Type: zip
RussK Idle-Airflow-IAC Scale.zip (996 Bytes, 190 views)
Old Feb 7, 2015 | 04:14 PM
JakeFusion's Avatar
Super Hulk Smash
Btw, the version of the Russ K idle tuner has my adjustments. It monitors dynamic airflow and desired airflow. If your IAC counts are all over the place or wrong, these are the numbers you need to get aligned.
Old Feb 8, 2015 | 01:45 AM
VandykeT/A's Avatar
The car was tuned with iac counts going to 0 so I adjusted the throttle body to get the counts between 40 and 60 but I'm still getting a hanging idle at times just not as bad and the car will stall now sometimes if I make a sudden stop throwing thr clutch in. It was also tuned with a vacuum leak.
Old Feb 8, 2015 | 07:39 AM
01MAROONz2890's Avatar
what kind of tb is on the car? i would get the raf in line but sometimes the tb can be an issue
Old Feb 8, 2015 | 08:51 AM
blackLS1m6's Avatar
If you tuned it with a vacuum leak you need to go back and dial in the Ve table and Maf first.
Old Feb 8, 2015 | 01:23 PM
VandykeT/A's Avatar
I wasn't the one that tuned it I'm just trying to fix some issues with it. And it's speed density tuned so no maf. And the car had a Nick Williams 102mm tb. It never had any of those problems until after the tune was done.
Old Sep 10, 2015 | 10:06 AM
elerico's Avatar
do we have to adjust iac steps ?
Old Sep 10, 2015 | 10:40 AM
mrvedit's Avatar
Moderator
Good question, especially if you have a non-stock TB.
Recently switching to the FAST 102mm TB and LSXR is giving me a moderate amount of grief. I know many people complained that the 90mm TB has IAC ports that are too small; not sure if the 102mm improved on that.
Old Sep 11, 2015 | 09:10 PM
JakeFusion's Avatar
Super Hulk Smash
NW is fine. So is the FAST most times. NW has a bigger IAC port opening.
