relatively low ignition advance when my car was tuned on the chassis dyno, it made its most power at 26.5 degrees advance at wot. the tuner gave it more timing but it didn't actually make any more power, so he backed the timing off to 26.5 degrees. does that seem normal? I thought most lsx engines liked around 28 degrees. i have a 6.0 with milled Texas speed 243s, 228r cam, and 11-1 comp. |
My understanding is 243s don't need much advance. If you understand the science ideally we could fire it at TDC but unfortunately the flame takes time to travel, and we have to light before TDC and waste some energy during the compression stroke. The idea more advance is more power is very 1970s. Modern stuff has more efficient chambers |
Originally Posted by mikesimpalass
(Post 18903390)
The actual timing number borders on irrelevance. If the dyno says that's where its happy, and its making appropriate power for the combo, then that's how it is. If you want to take anything from it, generally speaking, a motor that makes peak power with less timing has a more efficient combustion chamber. |
thanks guys, I wasn't worried about my timing being too low. i was more so just curious as to why my engine was happy with less timing. are the 243 combustion chambers really that much more efficient? |
(Post 18905292)
© 2024 MH Sub I, LLC dba Internet Brands
