Help! Built LS1 won't idle! P0102 Freshly built LS1 will not idle on its own, has the following mods: Fast 102 intake/TB PRC 227 Heads Ms3 Cam SLP lid 42 LB injectors Longtubes True duals Car starts up and runs great, drives great, however at idle it just dies unless you feather the throttle. The only code it's showing is P0102. The car is of course tuned for the mods have had several re tunes with no luck. Open to any suggestions that may help solve this! |
Also on HP tuners it shows no fuel trim what so ever, what would cause this? |
They are turned off or it is in open loop. P0102 could be because it was tuned in SD mode. Without seeing a tune file who knows. |
Post the tune. That cam will take a little finesse to idle. Sounds like you don't have the TB cracked open enough to feed it air at idle. And, as 2xLS1 said, you're probably in Open Loop for no fuel trims and in SD mode (disabled incorrectly) for the P0102 code. |
| All times are GMT -5. The time now is 03:04 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
