Diablosport Predator will not communicate
So when I bought the car the owner gave me the married programmer that he had purchased for the car in 2012.
About a month ago I used the programmer to check codes, and reinstall the stock tune on the car after a header install and it worked like a champ.
This past weekend I was going to try my luck at trying to tune a bit. When I plugged in the scanner it booted as normal. Turned the key on and went to diagnostics/read codes. The tuner came back with cannot read codes verify key is in the on position and try again.
Did that with no luck, tried reading the VIN and the predator says cannot communicate.
Plugged in my MAC Mentor and looked at codes, data logged, cleared codes. So the problem is not related to the pcm or dtc port.
Is the DS Predator garbage now?
LS1Tech Sponsor
in between the time you restored the original backup stock tune and a month or so later trying to use it again when you got the error, did you add anything aftermarket to the car like aftermarket stereo, subs, amps, nav, remote start, alarm, etc.? if so, you need to disconnect them.. something is blocking communications from the predator to the pcm.
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
