1998 F-Body fan questions
Old 06-09-2004, 10:07 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
Default 1998 F-Body fan questions
Anyone familiar with the fan connector, ie. the breakdown of the pinouts? I put a standalone computer on my car (FAST bank/bank) and need to wire up the fans.
Old 06-09-2004, 03:00 PM
LS1Tech Co-Founder
We have two fans right?
Old 06-09-2004, 03:16 PM
horist's Avatar
yup 2 fans ... i dunno the pinout though
Moderator
jimmyblue's Avatar
I can get you the Helm book info for a 2002,
though I'm not 100% certain it's identical on
a '98, if that'll help. There are two fans, a low
and high speed mode (but I don't know offhand
if this is windings, or parallel / serial relay
connection etc.
Old 06-09-2004, 03:19 PM
SidewayzOZ's Avatar
I believe the fans are the same throughout the obdi and obdii year fbodys (As far as series, parallel turnon goes). I have a link to a wiring diagram that might could help you out. Its not pcm pinouts but it does give you access to turning on the fans (both high and low). Let me know what ya find out...
http://users.oco.net/xero/fanmod/
Old 06-09-2004, 03:45 PM
slow's Avatar
Im not sure where you splicing into the fan connectors, are you using the factory relay boxes? I would if you still have them. The easiest place to tap into them is On the passenger fender there are 3 metripack connectors, C100 C101 and C105, you want to deal with the C100 10 pin black connector.
pin H is the high speed fan and pin J is the low speed one.
I can get you the mating connectors if you need them. for connector C100 simply remove the connector from the pcm side of the harness and splice in there. You need a ground signal to activate the relays.
c100 10pin black
a-pnk-pwr from fuse 9
b-grn/wht-a/c comp relay control
c-dk grn-a/c comp clutch solinoid feed
d-(europe)-gry-ref voltage feed, 5 volt
e-(europe)-dk blu-tps signal
f- not used
g-pnk-pwr from ign fuse
h-dk blu-coolant fan relay control
j-dk grn-coolant fan relay control
k-(europe)-blk-sensor return
just send me an e-mail if you want the connector/pins, i've got lots of them, and will be glad to help you out.
all 1993-2002 use the same pin H and J for the fans (except 1993 single speed fan, they just use 1 pin)
Ryan.
Old 06-09-2004, 04:03 PM
LS1Tech Co-Founder
We removed the engine control harness.
I could go thru and use your info and probably wire in the fans we'll try thanks so much guys.
Old 06-10-2004, 10:52 AM
LS1Tech Co-Founder
Thanks a lot guys, you were very helpful, we wired up the fans last nite.
Old 06-10-2004, 12:10 PM
slow's Avatar
no problem, glad we could help
Ryan.
Old 06-10-2004, 02:57 PM
SidewayzOZ's Avatar
Ryan.
ditto And thanks for the extra info slow, its always nice to know what wires do. Since PSJ is done with this thread, Im gonna hijack it...How much info do you have on the ls1 wiring? Im looking for a couple things specifically that you might could help me out on.
Old 06-10-2004, 03:00 PM
slow's Avatar
i don't have too much more info as far as oinouts, i got that from another thread in the conversions and hybrids forum.
but feel free to send me a pm and i can try to help. I know a decent amount about the way the systems work.
Ryan.
Quick Reply: 1998 F-Body fan questions
